LFMV1645TF Frigidaire microwave died. New fuse?
zamboknee
Des Moines
LFMV1645TF
Frigidaire
Our Frigidaire LFMV1645TF microwave died in the middle of useage.
Breaker didn’t trip, the outlet is fine.
I’m wondering if it’s just the fuse inside blowing.
Can I just replace the fuse here or do I need a new microwave?
House fuse.
House breaker.
Fuse inside the microwave.
Thermostat inside the microwave (esp if someone has burnt food).
LINK> Line Fuse
It is #34 in the parts breakdown. Top front grill comes off to access that area.
jeff sr.
zamboknee
Des Moines
i put a new fuse in. It was working fine but then my wife was cooking popcorn, opened the door WITHOUT hitting 'stop' and it blew the fuse and tripped the breaker.
The obvious answer here is 'well, don't do that,' and I've advised my wife to hit the 'stop' button from now on so as to rule that out. But she swears she's done this before (opened the door while still running) a million times with no problems.
Is it the door opening during running? Or do I need to explore other causes?
Normally not an issue.
Yes, door switch or door switch mechanism issues.
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Door switch part help.
jeff sr.
