- LFSS2612TP3
- Frigidaire
- 1-5 years
Frigidaire Refrigerator LFSS2612TP3 has developed 2 cracks on inside freezer side wall. The unit is 2-1/2 yrs old and I have a 5 year extended warranty purchased at Lowes when in i bought the unit in July 2020. The warranty is apparently serviced by Assurant and/or Electrolux. i called a couple weeks ago. they sent a tech out and he said the only thing they could was put a piece of tape on it. I said one crack is 19" long, appears about 1/8" wide and seems to be going down the freezer wall and behind the back wall plate of the freezer. the other crack is above the large one and is not as wide and is about 6" long. I said i dont want a piece of tape put on this large of a crack. and it needs to be inspected to see if it is continuing behind the back plate. Tech said that is all they could do. But i could call Frigidaire about it. I did call Frigidaire and they said the OEM warranty is one year and they dont have any responsibility after the one year. I called Assurant again and they sent out another tech. He said the same thing, "we can tape it or you can call Frigidaire" I called Frigidaire a few times and asked to speak to someone higher up about the problem. Both Frigidaire and Assurant said they would have a supervisor or some one call me back. I'm still waiting on a call from either one of these agencies. Also when the fridge was originally delivered one of the handles had to be replaced. Then a few months later the doors were uneven. and not leveled. three trips later the doors were never leveled. (one tech came out and said the hinge needed to be "Bent up" to make it work. The second tech said he needed to piece of wood in the hinge to make it work. The third tech ordered a hinge and installed it and it never was level. I would like to get this fridge replace. Any thoughts? thanks
