LFX25778ST/00 LG French door bottom freezer not cooling at all.
boudro
calgary
LFX25778ST/00
LG
My LG model #LFX25778ST/00 French doors bottom freezer refrigerator is not cooling at all, it is reading F: 8 degree F and R:46 degree F.
Controls are set to R: #6 degree F and F: -4 degree F. Not sure what is wrong?
Pull the refrigerator out from the wall, then remove the rear lower back access panel and get a flashlight and see if the condenser fan motor is running, it mounts next to the compressor.
Also put your hand on the top of the compressor and see if its warm and vibrating.
boudro
calgary
Hi Jake:
Actually removed back panel and condenser motor running and compressor hot to the touch .
Ok, that means the compressor is the culprit if the compressor is hot and running and your not getting any cooling at all.
Contact LG Canada at 1-888-542-2623 and see if you have any warranty left on the compressor, some LG models have up to 10 years warranty on the compressor.
