Misterfixit1967
- LFX31925ST/05
- LG
- 6-10 years
I have a 2014 LG LFX31925ST/05 that is not cooling well in the refrigerator or freezer. They are set on Ref 35 Freezer 3F, the current temps using digital thermometer are Ref 55F Freezer 36F. There are no error codes on the door panel. Both freezer and refrigerator fans are working fine, compressor is running with no LED light on PCB. Also the compressor line to the condenser is hot which indicates to me that the compressor is doing its job. It is not making any unusual noises. Both the freezer and refrigerator fans are working fine. The evaporator in the refrigerators section has frost on it. I haven't pulled the cover on the freezer evaporator yet.
This refrigerator died and went unnoticed for two days. I pulled the plug and let it sit for 15 minutes and plugged it back in again and everything appeared to be working well. After removing all the food I started disassembling and found what I mentioned above. It has been running for one day and was getting slightly cooler every hour. I pulled the main circuit board cover and ran the test using the test button on the circuit board. Everything works fine. As I mentioned there were no flashing LED signals on the circuit boardWhat to check next? Or should I just let it run for two or three more days and see if it cools down anymore? I have read that it takes several days for a brand new one to stabilize the temperature in both our refrigerator and the freezer.
