LFX31945ST/02 All look good but not cooling
osilfa
FL
LFX31945ST
LG
hi, i need help, my LG LFX31945ST/02 no cooling so i made test PCB and the test #3 do not display only test 1 and 2.
Any suggestion
Thanks.
Your missing a digit between the "9" and the "5" in your model number, we would need that first.
osilfa
FL
Yes the compressor running ok, and the fan next to the condenser too.
Rgds
Ok,
If the compressor is running and there is no frost on the evaporator coils there's a sealed system problem. The sealed system consists of the compressor, condenser, evaporator, heat exchanger, filter/drier and refrigerant. Common problems with a sealed system are bad compressors, refrigerant leaks, and system restrictions. Sealed system repair costs will often exceed the machines value.
Check your owners manual warranty, some models have up to a 10 year warranty on the compressor, and 5 yrs. on the sealed system, which includes the compressor.
