lg-pain
- LFX31945ST/02
- LG
- More than 10 years
Despite of the front control panel (next to the ice maker) being broken for about 10 years, my fridge has been working ok until 5 months ago. 5 months ago, It was getting colder in the fridge section and lots of water accumulation collected on the bottom of the vegetable trays more than often every month frequency. I suspected that may have something to do with the thermistor sensor? two weeks ago, the fridge stopped getting cold, and no more water accumulation under the vegetable trays. The freezer is however still working ok.
I did not feel any cold air coming up from the evaporator. I suspect it may have something to do with the evaporator fan motor stopped working?
Here are my questions:
1) can I just simply replace the evaporator fan motor and thermistor sensor without having to replace the front display panel for now? The fridge was working for about 10 years with the broken front panel. I suspected the fridge was working ok with the factory settings without relying on the front control panel ? The front panel electronics went bad from the ice maker leaking water into the front panel, I suspect. I saw an online post or two about people's front display panels were having the same problem caused by water leaking from ice maker.
2) can I test for the evaporator fan motor and thermistor sensor from the PCB board in the back of the refrigerator to see if they both are working or not before replacing them?
3) will the broken front control panel affect my test at the PCB board?I have a multimeter.
4) is it a simple task to replace the front panel? Do i need to reset the PCB board to accept a new front panel? The authorized tech had to reset the fridge to accept the new compressor which was replaced 6 years ago, he said.
