LFX31945ST/02 LG Refrigerator Error F dH
Beiss
Hamilton nj
LFX31945ST/02
LG
The resistance of the sensor assembly and heater tested ok so I replaced the control board but the error comes back after about a day and a half. I don't know what else to do so I'll just replace them and see what happens.
If its cooling fine like you said before, don't worry about it.:)
The fan motor you replaced already fixed it here:
Beiss
Hamilton nj
It cools fine, but I have to yank it out from the wall and unplug it every day and a half to reset the display panel and its functions.
Thanks again for your help.
Dennis
I don't know what else could be causing that Dennis, I will ask Rick.
Was the F dh coming up BEFORE your replaced that FREEZER FAN motor?
Push the test button on the main board 3 times.
Locate CON3 on the board and check for 120 VAC between the blue wire and the orange wire.
Press the test button once to release test mode an check for 0 VAC between the blue wire and the orange wire
Beiss
Hamilton nj
Test mode 3 - blue and orange = 120
No test mode - blue and orange = 1.1
Just to be sure, I used the top blue wire in my pic (I know enough about electricity to be dangerous).
Check the wire connector is on all the way. Measure the resistance of the defrost heater, Fuse M, and the defrost sensor. Post back the results.
