FIXED LFXS24566S leaking water when using water dispenser
Mark1118
Pittsburgh
LFXS24566S
LG
Everytime we use the water dispenser on the outside of the fridge water accumulates on top PC the freezer door, under the bottom storage tray in the fridge and eventually on the floor. What would cause this I did see a previous thread comment the same issue but on a different model. Would this be the same fix? Thanks for any help!!
Mark
It’s most likely a leak at one of the fittings so it’s just a matter of following the line back until you find it. Look around the water filter “In” and water filter “out” connections then do the same for the water tank.
Mark1118
Pittsburgh
Thanks!! I did order a new water tank AJL72911502 to be on the safe side. It is hard to tell where it's coming from since I can't view with the door shut, but they're is water everywhere in that compartment.
