LFXS28596S Lower hinge assembly
Okumabob
USA
LFXS28596S
LG
The right side refrigerator door does not close as it once did. There was noticeable effort about 2” before closing which I’m assuming was some spring assembly in place to keep it closed. That spring effect is now missing and the door will pop open when the left door is closed. Took the door off and found a white bushing with pieces broken off and some obvious wear and tear. Looking to see if anyone knows the correct part numbers to order to fix the door. To be clear, the door I’m talking about is the main door, not the glass door in door.
I can't locate a decent parts diagram for this model, you will need to take your model number with you to your local appliance parts store in your area and they should have a good parts diagram to get you the part/parts you need to fix it.
