LFXS30796S Lg Refrigerator E rF Code
DennisP
Boerne, Texas
LFXS30796S
LG
Refrigerator started making odd noise. Next morning I got error code E rF. Found indicates abnormality in fan motor. Unplugged. Plugged back in, no error code, but returned 2 hours later. Which motor? Condenser or Evaporator? Cannot find a repair manual on this unit.
Error refrigerator Fan is logged when the control can't read the feedback signal from the fan motor. Access the main control board and locate connector CON6. Go in thru the back of the connector with your meter leads on Pin 3 and Pin 5. Press the small test button on the control board one time. Verify airflow in the refrigerator compartment. Your meter should indicate 8V-12V DC. If the voltage is correct measure the voltage across Pin 1 and Pin 5. If the voltage is 0V or 5V replace the fan motor.
