LG air conditioner LW8015ER compressor won't turn off
kevcri
connecticut
LW8015ER
LG
when i turn off the air conditioner the compressor stays on, even if the unit is off. My question is what part do i need to replace, and where can i find one?
thank you for your help.
kevcri
I can't get your model# to work on any parts sites....but it appears to be a good #.
You might have to speak to LG directly ( shudder ) for parts.
You have a bad relay/pc board.
Compressor relay is stuck.
You will need to pull the unit apart and behind the control board you will see another board with the relays on it . Unplug the unit before doing this and make sure not to touch the capacitor because it holds a charge. There should be a part number on the board that has the relays that you can look up
