LG Dishwasher LDF7774ST Water Leaking Bottom of Door
kola
Midwest
LDF7774ST
LG
Got the AE error code. Uninstalled float, removed water, and reinstalled float. Removed the outer skin of the door to inspect for leaks. Started cycle. Water comes out the bottom of the door during the wash cycle. See video.
Is this due to a failed door bottom gasket? Also read that a possible cracked spray bar may be shooting water directly at the seal.
Found a post on this site that the door gasket is not a replaceable part because crimped onto the inner door. The entire inner door must be replaced. Part (AGM34891603) cost is $250+ shipped.
I'd first remove the lower spray and inspect it closely for cracks in it, that would definitely cause that water coming out the door like that in your video.
Here's the lower spray arm for your model:
Nozzle Assembly
Ok, sounds good.
