LG Dishwasher LDS5540ST FE error code
Prak
British Columbia
LDS5540ST
LG
Hey,
Have an LG dishwasher, LDS5540ST, getting an error code FE come up after it has filled and ran for a few minutes. Sometimes the error doesn't even come up with middle of the cycle. Checked the float assemblies on the side, cleaned them out, and tested the switches. All seem ok. Any ideas what might be causing this error to come up? Thanks.
Error Code FE Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.)
Are you getting excessive water when it fills?
Water Inlet Valve 5221DD1001E
If the water inlet valve is fine, then the service manual says to replace the main control board.
EBR73739203 Pcb Assembly,main
Glad to help!
