- DLEX3570W
- LG
- 6-10 years
Hi I have a LG Dryer DLEX3570W which is about 6 years old
I am having issues with error code d80, d90, d95 and the dryer shutting off earlier and leaving clothes wet/damp. Below are the steps taken so far and really confused on what else I should test.
- cleaned the ductwork and checked inside the dryer for lint - all is clear.
- replaced moisture sensor
- ran dryer with ductwork connected - same issue
- ran LG diagnosist test - all fine
- tested a number of parts for continuity (high limit thermostat, thermostat, thermistor, thermal fuse) - all came back fine
Any thoughts on what else I can do? Is a continuity test an accurate way to test the above named parts or should I replace them?
