LG Dryer DLE3777W Won't Heat
Butch20
Wisconsin
DLE3777W
LG
Hello! My LG dryer model #DLE3777W runs but won't heat. I replaced the High Limit Thermostat and the dryer heated for one cycle and then no heat after that. Next, I replaced the thermostat and still no heat. Could it be the thermistor? Looking for recommendations of what to do next.
Thanks so much!
Butch
Hi Butch,
Ohm test the thermistor, make sure the dryer is unplugged when ohm testing.
At 70 degrees the resistance should be 9.3K ohms, 90 degrees would be 7.7K ohms. at 100 degrees would be 6.2K ohms, 120 degrees 4.3K ohms. If the thermistor reads outside of the range then it needs replaced.
Here's the thermistor for your model:
6323EL2001B Thermistor Assembly
Ok Butch, sounds good.
