LG Dryer DLEX3360V - Light on but no power
Rgbraun1
Texas
DLEX3360V
LG
DLEX3360V dryer.
Hello all, New to forum.
I have the above LG electric dryer. The light comes on when I open the door but When I push the power button the panel does not come on.
Any suggestions on a fix ? Thank you very much for your insight and expertise.
Rgbraun1
Texas
Will do. Will a bad door switch cause no power to the panel though? There is no power when I push the power button. The light does turn on when I open the door.
The Neutral side of power for the control board goes through the door switch.
Rgbraun1
Texas
Hey Rick. Door switch is good. Door light still comes on but no power when I press the power button.
Rgbraun1
Texas
Rick. Is that the board on the side of the dryer (inside) or the two pieces behind the power, start, knob etc buttons on the front?
I don't see any board on the side. All I see is the UI and the main board in the console. Did I miss something?
Rgbraun1
Texas
I’m probably using the wrong terminology. I just noticed your link to the part (control board). With the top off my dryer and standing at the door…the link/part you sent me is attached to the right (inside) of the cabinet and has about a dozen plugs plugged into it.
Rgbraun1
Texas
Making sure I’m not needing the display board/control panel. With all the buttons and knob.
Rgbraun1
Texas
Rick is it okay that my board has that black round piece and the link you sent me does not. See pic of my board.
Rgbraun1
Texas
Rick. I did some research. My board has a sticker that reads ERB 627076-31. When I look for that part online it looks like it’s missing parts. My board looks like ERB 627076-29. Should info with that one ?
Rgbraun1
Texas
"should info with that one" should read....should I go with that one...the -29 part number?
That's the same part in post #8. It's best to go with model number when ordering parts. Don't go by pictures or old part numbers.
Rgbraun1
Texas
If you look at my picture I posted, there is a round black thing, about an inch in diameter in the lower left side. That piece is missing from the link you sent me.
