dougefresh
- DLG2141
- LG
- 6-10 years
I have an LG Dryer (PN DLG2141) where the drum baffle looks to have come unscrewed from the drum (see pic below). I haven’t found the screws and don’t know the screw type, diameter and grip length.
Are replacement baffles available and easy to install? It appears that the dryer front cover may have to come off to be able to get to the outer drum shell to install the baffle screws for installation? I may be able to just re-install new screws into the existing baffle, but the baffle is plastic so I’m concerned that the screw holes may be stripped or not retain the screws under dryer load…or, it’s a baffle assy (baffle + screws)? It may be better to just buy a new baffle, but I can’t find the part number for my LG (or screw info).
I also was unable to find instructions on the process to replace the baffle.
I’ll probably still have to run the dryer until I get this fixed, but I’m assuming the only loss in doing this will be efficiency (lack of clothes separation, so less efficient drying).
Jake, I’m hoping you’ll be able to help me out as you’ve always been great at providing video, links and part numbers!
