LG Electric Range LDE3017ST Front Right double burner not heating
pdartley
Boston
LDE3017ST
LG
Hello
The front right burner stopped working about 4 months ago. The control button for this burner appears to be working fine as I can turn it on and I can set the temp.
I removed the heating element and didn't see any breaks. I replaced it just in case but it is still not heating. The rest of the range is working fine.
Is this an issue with the boards? If so, I don't believe it's the display board but not sure which one?
Please adivse
These are the RIGHT FRONT burner relays. You can see if those relays are OPEN when the RIGHT FRONT burner is ON with a meter set on AC volts. But be very careful not to touch anything else when testing live electricity.
RY15--->9 inch burner
RY14--->12 inch burner
Here's the cooktop burner relay board for your model:
pdartley
Boston
Hi Jake
Thank you very much for the response. It took a while but I finally got around to replacing it. Even though my manual and the model sticker on the stove indicate it's an LDE3017ST, the relay board looks like the one for the LDE3037ST (pls refer to the pictures below). Any thoughts? I tried looking up the EBR732545 but didn't find anything. Is it worth trying to replace it with the LDE3037ST (https://click.linksynergy.com/deepl...-pcb-assembly-main-ebr73821007-ap5785746.html)
Thanks in advance for any feedback.
