LG LFC20770ST The ice is not dumping
LiteralLoki
South Dakota
LFC20770ST
LG
Ice maker in the bottom drawer is “slabbing”. The ice was not dumping, so I thawed the ice in the tray and reset it. It worked for three or four cycles and then it didn’t dump the ice. This caused the water to pour over the top of the ice in the tray and onto the bin. I’m not sure if the tray is turning over and the ice isn’t coming out or if it isn’t turning over at all. When I push the reset button the tray rolls over but the ice doesn’t fall out. Any suggestions? Thanks in advance for your help.
The ice maker itself is the problem, that's what you will need to replace to fix this issue.
Here's the ice maker for your model you can order(Video Included in part link):
Ice Maker Assembly AEQ72909603
