sonicblaze
- LFX21980ST
- LG
- More than 10 years
I purchased a new water valve for my LG LFX21980ST. The old valve was 2 solenoids into a single water outlet (leading to the filter, where post-filter the line splits to water/ice). The new valve is a single solenoid with a single outlet, which works great for water but the ice maker is not getting water.
I tested the terminals from both harnesses on the old solenoid, and it looks like 1 terminal set was for water, 1 terminal set was for ice. So the fact I only have 1 plugged in now (due to the single solenoid terminals to connect it to) leads to only activating the solenoid for 1 of the functions.
I did test for 120v on both of these harnesses and found the red one is the water, the blue one is the ice maker, and both properly activate 120v when triggerd.
Is there a safe and appropriate way I can splice these together so both harnesses control the single solenoid? Is it as simple as splice the blues & splice the red+purple, and only leave 1 resistor box?
