FIXED LG LFX31935ST/03 back wall was covered in ice, 2" thick.
Mark T
st. louis
LFX31935ST
LG
I defrosted a few minutes till big chunk came off. I opened the back wall and was surprised to find no ice on the coils. There were no error codes, I just saw a lot of frost. Defrosted the unit, put back together plugged it in, ran fine. Next morning had error F dh. I unplugged and plugged back in after few minutes. It has been more than 24 hrs. on error codes. Any thoughts??
Hi Mark,
Error Code F dH = Freezer Defrost Heater Error
Unplug your refrigerator first. You will need a multimeter to ohm test it.
Here's how: Remove the defrost sensor controller from the freezer side evaporator. Put the sensor inside a small glass and fill it with crushed ice, then just enough water to cover it. LG sensors have a slow response time so leave it in the ice water for five minutes then measure its resistance. At 32*F the sensor should be at 30K ohms, +/- 5%.
Here's the defrost sensor controller for your model you can order if yours tests bad:
6615JB2005R Controller Assembly
There is a video in the part link that shows you how to access it.
Mark T
st. louis
Thanks for the response. I saw that you had advised the same for a similar situation. I will order, test and post my resuslts.
Mark
Ok Mark, sounds good.:)
Mark T
st. louis
follow up on repair
fixed, I hope!
replaced defrost sensor on 4/4 , no error codes, yay!
in the picture, notice that the orange leads are shorter that original, hope this doesn't cause an issue.
Thanks Jake,
Excellent Mark, glad to hear the new defrost sensor controller fixed it. (y)
Hopefully that will be fine.:)
