LG LFXS32726 error code E rf
Jfleshman
Portland, Oregon
LFXS32726
LG
For approximately a month our unit was making a noise inside the fridge portion of our French door refrigerator. came back from vacation to a warm refrigerator portion and the freezer was still working. After looking at several possible fixes, we started in the freezer and replaced both do motors there. That was a non fix to the problem. I see that it could be a fan motor located inside the upper unit but I am having difficulty figuring out how to get the panel off. There are no visible screws to remove. I'm a pretty handy gal but this one has me stumped.
Jackie
Remove the two screws in the lower guide rail and remove the guide rail to get it out of the way.
Use a small flat blade screwdriver and remove the upper and lower caps on the center shelf support then remove the two screws.
Pull the duct out a few inches and disconnect the wire connectors.
Use both hands to remove the multi duct
