FIXED LG LMV1683ST Microwave with multiple symptons
Chrm421
MA
LMV1683ST
LG
Hey guys,
Have a microwave that is having multiple issues. I've searched the internet for answers but my problem is for multiple symptoms.
At first the unit would work normally for 1-2 minutes then the heat,turntable,light would all turn off for about 5 seconds then back on and work normally for another minute or so and then repeat problem. However the exhaust fan would work normally the entire time. Now the unit will not heat,turn,or light come on at all. Light wont even turn on with door open. The only parts I've replaced is the entire door switch assembly and also plugged unit into a different outlet but same problems.
Any suggestions would be greatly appreciated. Thanks! :D
I'm assuming the problem started before you replaced the door switch assembly. The power cord connects to a noise filter (circuit board) that has a ceramic 20 amp fuse on it. Check the fuse for continuity. Follow the white wire from the noise filter and it connects to the oven thermostat. Check that for continuity also. Follow the black wire from the noise filter and it also connects to a thermostat. Check for continuity.
Line Fuse 3B74133Q Order now for same day shipping. 365 day return policy. RepairClinic.com
High Limit Thermostat 6930W1A003E Order now for same day shipping. 365 day return policy. RepairClinic.com
Chrm421
MA
Thanks for the quick reply Rick!
I checked the continuity on both thermostats and fuse. All seem to be fine.
Chrm421
MA
I'd like to thank rickgburton! It was the control board! I appreciate the time you took to respond to my problem. You saved me a decent amount of cash and I am forever grateful!
