BillInFlorida
- LMV1762ST/01
- LG
- 6-10 years
I saw this same exact problem in a post here from 3 1/2 years ago for this microwave. Without opening it up, as I didn't have time, I ordered a magnetron based on that post so I could get the part delivered asap.
It didn't fix the problem. At that point, since the unit was down off the wall from under the cabinet, I got out my meter and did some checking of all the major components listed in that other post. They all checked good as far as I could tell. Then I checked the LG EAF36358314 Fuse Assembly. No continuity! Doing a search for that part, I found that I wouldn't be able to get it for several days.
Inspecting the Fuse Assembly, I discovered that it splits open, and inside it takes a standard 0.9 amp glass fuse. A quick trip to the hardware store got me a 1 amp slow blow fuse, which would have to suffice as I'm going out of town for several days and the wife needs her microwave! The hardware store fuse is slightly shorter, but the same diameter at the ends so it fit well enough in the fuse assembly.
My question is what caused the fuse to blow? Could it have been the mag tube which I replaced, or something else? The fuse assembly runs between the HV Capacitor and the HV Transformer.
