LG LMV2031 Should I replace my Microwave?
graphoto
Florida
LMV2031
LG
I have an LG microwave LMV2031 that is only 3 years old. On the last use it was louder than normal and now it does not heat. I went through LG troubleshoot - everything else works fine keypad, timer, lights etc. and it sounds likes its working... but what good is a microwave if it doesn't heat anything?
LG Warranty only covers the magnetron but its $90 just to have service come out, not including hourly rate to fix and they said other parts would be needed so could be $300-$400 (and may not even be the magnetron.)
Is there something else I could check that is not on LG troubleshoot such as a fuse or is it just time to buy a new microwave?
How much is a new microwave in your area?
Is the colour you have available?
jeff sr.
$300-400 for a new microwave and yes stainless is available. But after this not sure I’d buy LG again.
Est repair cost the same as a new one = happy shopping time!
Your complaint does sound magnetronish for sure.
jeff sr.
