FIXED LG LMV2073 Micrwave dead
larrywick
Novato, ca
LMV2073WW
LG
LG LMV2073WW Microwave
Hi, there is power to unit, but it is completely unresponsive, no light when door is opened, no display. Line cord is plugged into noise filter circuit board which has fuse on it. Fuse is good. A black and a white wire are plugged into board, white goes to oven thermostat and black goes to M.G.T. thermostat. If I am reading the circuit diagram correctly the black should always be hot, 120volts. It is not. I am thinking that a component on the noise filter board has failed and it needs to be replaced. Do you agree?
all Microwave Display Repair Sharp Dacor GE General Electric
service manual for similar machine
Thanks for any help
Larry
Unless the polarity of the outlet is backwards.
What was the readings? Where was this taken?...and how?
Dead....often the fuse, fuse holder, flame sensor/thermostat, wiring between.
larrywick
Novato, ca
Thanks Jeff1 for your thoughts,
Polarity at outlet is correct, voltage there and at both sides of the fuse holder is 122.9 using a digital multimeter.
Could I temporarily bypass the noise filter without harming the microwave to see if that is what is keeping it from operating? I am assuming that the noise filter is there to condition the input voltage.
Larry
That would indicate the fuse is good. Leave one needle on the neutral ( white ) and if you get 120 volts AC with the other lead on both sides of the fuse holder the fuse is good.....a bad one will have 120 volts on one side and 0 ( zero ) on the other. Can also remove the fuse and ohm meter test it.
Usually yes.
Thankx for the update :)
