LG LMXS30776S/01 Icemaker not filling with water
Larry57
Kansas City
LMXS30776S/01
LG
I Have been troubleshooting a LG LMXS30776S/1 Ice-maker that doesn't fill with water. I have changed the ice-maker unit and the lower Water inlet Valve and filter.
The Ice-maker motion is complete during the test function except not flowing any water into the tray at the end.
The water pressure to the fridge is testing good.
I have water to the door and it will dispense water at the door.
I have the manual with the parts breakdown, but the breakdown doesn't reference a part nomenclature. It shows the part with a document number but no description tied to the part.
I know the there is another water valve in the lower part of the door, wish I could find a description and how to test it.
Tired of troubleshooting with part replacement. I know my way around a multi-meter but cant find any troubleshooting manuals on how to test the valves or electrical boards and sub-boards.
Any help/references would be much appreciated.
Thank you
Larry
Hi Larry,
Yes, there is a water inlet valve in the left side door.
Here it is for your model:
This video should give you the general idea of how to access it:
What I do to test it is cycle the ice maker and get your meter and take the electrical connector off the ice maker side of that water inlet valve and put your meter probes in that electrical connector and watch your meter for 120 volts towards the end of the ice maker cycle, when the ice maker should fill with water, if you get 120 volts for about 5 to 7 seconds then that water inlet valve in the door is the culprit.
Larry57
Kansas City
Thanks Jake,
The Ice maker side of the water inlet valve in the door that you referenced above isn't getting power to the Ice maker side. So that points to wiring, sub-board, and main board. I definitely would prefer not to troubleshoot with part replacement on these boards because I bet they are far from cheap. Any electrical schematic available? Does anyone have any other advice short of just replacing boards? I know I am probably down to a 50/50 chance on which board it is, but I would like to know as close to 100% what is failed before I start buying a board.
Thank you again,
Larry
Larry57
Kansas City
Hi Jake,
Thanks again for responding and trying to help me. I have that manual, but unfortunately I couldn't find any reference in it concerning my problem related to troubleshooting no power signal to the water inlet valve in the lower part of the right door. Specifically, accessing the sub PCB board and how to troubleshoot any PCB board short of just changing it. I would prefer to avoid changing parts if not needed. Any other ideas?
Thanks again,
Larry
Nope, sorry Larry, that's all I know to do as well, LG makes their service manuals very vague, unfortunately.
absolut_riley
South Carolina
I have a similar ice maker issue with my LG refrigerator LMXS30776S/03. My in door ice maker doesn’t make ice UNLESS I manually reset the ice maker AND keep the door open at a 45 degree angle. If I close the door after hitting the reset button I can hear the ice maker go through the process of rotating down and back up into place and I hear a click but water doesn’t fill the tray. If I leave the door open at 45 degrees it completes that same process but after the click water fills the tray. Water will immediately stop flowing if I open the door more then 45 degrees or close the door. I have replaced the main water inlet valve (back of fridge) and the valve on the door, but neither made a difference. I suspect there is a kink in the orange water line that goes from the in the door water valve to the ice maker but I wanted to check here before I took the door completely apart to replace that hose. Plus, it’s not clear what part number that hose is from the LG parts catalog. Any thoughts on what might be causing this and how to fix? Thanks!!
