Puddintane
- LRE3023ST
- LG
- 6-10 years
I have an LG model LRE3023ST electric range. While the oven was preheating and during subsequent use of about a 20 minute baking time I could smell hot plastic. It maintained heat the entire cook time. When we tried to use the oven again a couple days later the display worked and showed the base level temperature (110°?) the oven is turned on but nothing would heat up. Neither the broiler nor the regular oven. I tested the temperature sensor and it showed the proper ohms reading (~1080). Both of the heating elements (broiler and regular oven) show continuity. But the main power supply line (black) that comes from the junction block to the relay (RY106) on the oven relay board had melted the insulation on the end of the wire and separated from the connector where it connects to the board. The relay also suffered some heat damage where the wire connects. Also, the breaker hadn’t been tripped. The unit had power throughout.
I removed the oven relay board and tried to desolder the relay, but those little retaining rings around the hole in the PCB (for the two bigger lugs) got damaged. So at a minimum I assume that I would need to replace that board. I’m wondering also if I need to replace the entire wiring harness, because it looks like that black wire that connects to the relay is part of a conjoined two-strand wire, like a lamp cord, where it attaches to the junction block where the outlet cord is attached. (I think the other part two-strand wire goes up to power the relay board at the top for the display and the burners.) So it doesn’t look like that black wire is individually replaceable.
One other thing that I noticed was that where that black wire connects to the power supply junction block the connection wasn’t previously completely snug, because it would move around a little bit. But the problem ultimately occurred at the other end causing the failure where it attaches to the relay. So I’m wondering if replacing the entire wiring harness is necessary. And also if replacing the harness along with relay control board would solve the problem. I’m not sure what caused it to fail at that point in the first place. Would there be anything else that would have caused it, or will replacing those two things do the job?
Hope this isn’t too long, but I tried to be clear and thorough. I attached a couple of pictures of the relay board and damaged wire (don’t know why it’s altering here the orientation of the photos – my apologies). The damaged relay is the one with the gray (looks white) wire and the black wire (bottom right first photo, top right in second photo). Thanks in advance for any and all help.
