FIXED LG LRSC26923TT - Ice Maker Woes
sealove67
CA
LRSC26923TT
LG
The ice maker is working properly, though ice does not dispense. I've gone through all the troubleshooting tips and from what I can tell it is because the ice bucket does not sit on the motor properly. If I insert the bucket and make sure it is all the back, ice will dispense one time. However, after that you can hear the motor running but nothing happens. When I open the freezer door, the bucket had slipped forward, which is why I assume it is not seating properly. Any ideas? Thanks! Chey
The ice bucket locks into place when it's installed correctly. You usually need to squeeze a latch or lift the ice bucket to get it out. It sounds like whatever locks it in place is broken. Does it make any noise?
sealove67
CA
Hhmmm .... that makes sense, but I don't think there is a latch (see attached). I'll go futz with it to see if a "lift" is the trick.
Looking at the ice bucket I see the front cover sits lower and I see tracks on the side so it must slide in on rails. Check there.
sealove67
CA
It does slide in on rails. I wiggled it around a bit and it seemed to seat better and has been working since. I am giving it a couple of days before claiming victory, but I think you solves this one, Rick. Thank you!!!
sealove67
CA
UPDATE: The bucket does seat properly when inserted, and it cannot be pulled out without a little lift up. But .... it unseats somehow when I crush ice. Regular dispensing of ice cubes works just fine. Something with the crushing action (it works for a second or two) sets it askew. Any thoughts on that one? I do love my crushed ice!
sealove67
CA
Yep, it looks like you are right again. The "nub" on the back of the left slide has broken off. I just ordered than one, plus a new ice tray. Still holding off on claiming victory, but you sure are smart and helping me out loads!
sealove67
CA
Glad we could help!
Drats! That didn't work, either! The ice crusher works for about 3 seconds, then you can feel the bucket being kicked out of place, and the motor still runs but nothing happens. Any other ideas?? I'm determined now to have my crushed ice!
That's what I was trying to explain back in post #8. Guess I didn't do very well. You probably need to replace both side rails. The problem is only that one is available. The other side is not.
4974JA1063A Guide,rail
sealove67
CA
I was hoping it was kismet that you only had the rail that was visibly broken. When can you get the other one in?
We don't order or sell any parts. We can only link you to a parts site like RepairClinic or AppliancePartsPros. You can try an online search with the part number. Can the old one be repaired? (I can't see it so I don't know what's worn or broken).
