LG Microwave Error Code
ghoppe
Pittsburgh
LMV1813ST
LG
When I use the sensor settings (sensor reheat, cook, popcorn, etc) on our LG microwave, after a few seconds, the microwave stops, beeps and flashes "F-4" on the display. Any clue to what this means and is it an easy fix?
So appreciate all your help!
May or may not help.
I couldn't find an LG microwave fault code list. Some/many others have the F4 as a bad sensor.
I did find this...
1. Disconnect sensor connector from micom
computer board.
2. Measure resistance terminal to terminal (ohm
meter scale: R X 1000)
Normal:
Approximately
BK-RD: 6.0 Kohms
RD-WH: 3.0 Kohms
BK-WH: 3.0 Kohms
Abnormal:
Infinite or approx. 0 ohm
Sensor-6501W1A013A--01058057.jpg Humidity sensor assembly Manufacturer Number 6501W1A013A
