LG Microwave - Turntable and Smell
sears_critic
Earth
LRM1260SW
LG
I noticed a smell like burning plastic coming from the microwave, and it's not from the inside.
Then the turn table stopped working, but the smell persists occasionally.
Could this just be the turntable motor?
Maybe it's time to buy an OHM Meter.
peace
wildimaginations
Danville, California
Hard to say what it would be but if the turntable motor has stopped working, it may be the problem. Remove the access plate at the bottom of the microwave and do a continuity check on the turntable motor. If it's good, test for voltage on the wiring to the turntable motor. You should get 120v. If not, you will need to remove the cover and look further.
wildimaginations
Yes, you can run without the turntable motor. The only problem you will have is uneven cooking. You may have to rotate the dish every 30 seconds to evenly heat everything.
