FIXED LG microwve will not heat
slammin
Vancouver
LMV1813
LG
Less than 1 year
My LG LMV1813 microwave is 10 months old and suddenly stopped heating food. It runs and sounds like it's working normally, but food remains cold.
I only paid about $250 for the microwave, so I'm not even sure it's worth fixing. Thanks for your help.
Adam
Call LG for a warranty service call. It should have a one year warranty.
slammin
Vancouver
Always need to include everything on the model# tag...
...not from a manual, bill of sale, etc.
slammin
Vancouver
Fixed
Good luck with the repair! :)
Well, turns out it wasn't the magnetron after all. I read this in the service manual :
"If something is caught in the door or in the sealing
area, the microwave oven cannot operate safely. The
latch switches and monitor switch will prevent
operation."
So I ran the oven and repeatedly opened and closed the door, jiggling the latches and trying to ensure there was complete contact.
The cup of water started boiling so I guess that was the problem. I hope that this may help someone else with the same issue. :)
Lets hope it stays working a while! :)
Door switchs -normally- prevent the *normal* noises....like the control is counting down ok but fan, turn table and cooking have quit.
Thats exactly what I was thinking when I read this thread last night, how could the microwave run with normal sounds and it be the door switches?
Seems there's more to this than meets the eye.
slammin
Vancouver
haha, well you both were right! I went to heat some food and ...............cold food. So I thought...something is loose. I took it down off the wall, opened it up and
checked all the terminal connections, I found that one of the connections to the transformer was loose and snapped it in all the way. I also tested the magnetron with an ohmmeter and it was fine. I reassembled the case and now it works consistently. ...fingers crossed.
Thanks again for all your input
That would do that.....some even get loose enough and burn off.
Good catch!
