FIXED LG model LDE3017ST with no display at all
2mcc1
toronto
LDE3017ST
LG
I have power to the stove, however there is no display on the stove and all the buttons are not functioning. I replaced the SMPS PCB (EBR64624701) board and still nothing working on the stove. What should I do to trouble shoot this issue? Thx
Here's your service manual: https://drive.google.com/file/d/1W8nn493c1JIkXmjAt-dIhTur8bSMSxFr/view?usp=share_link Page 9-1 to 9-4 tells what to check.
Check your dual 240 volt breaker in your home breaker box, one or both might have tripped and that would cause this problem.
Do a dual breaker reset, meaning turn them BOTH all the way OFF, then all the way ON, and see if it starts working again.
If still nothing, then its possibly the thermal fuse blew. Turn the dual breaker OFF before you access and ohm test the thermal fuse.
Rick helped another person with your same model here:
Here's the thermal fuse for your model:
Thermal Fuse 6930W1A003X
Watch this video to ohm test the thermal fuse:
Yes I checked the wiring and there was an issue with the common wire. Thx again I appreciate your help
Sounds good, glad you found the problem.(y)
