LG model# LMXS30776S light blinks 6 times on board
n1vzx
new hampshire
LMXS30776S
LG
Less than 1 year
Im working on a unit that the compresser starts for about 10 seconds then power is gone then the green light on the boards blinks 6 times then pauses then blinks 6 times and does that over and over. Any ideas what that means?
Wild is our LG and Samsung expert here, you might want to try to reset it, look at his post#4 here: Help with LG error code
That model number in that thread and your model number are the exact same.
wildimaginations
Danville, California
LED blinks 6 times, then repeats (Current trip).
You may have a problem with the sealed system. Compressor is running at high current causing circuit to shutdown and wait 6 minutes to try again.
Is the compressor extremely hot to the touch? If so, you may have a blocked sealed system or the compressor is running extremely hard. You will need to tap into the high side and see what kinds of pressures you're having.
Hope this helps.
n1vzx
new hampshire
It doesn't have enuf time to get hot-it was running ok before I removed the freezer cover and noticed that all the molex plugs we not plugged in.since I put it all back together is when the blinking light started.
wildimaginations
You will need to have someone who does sealed system work come out and determine if the compressor is the problem or a sealed system is blocked. This is a major job and you will need to have special equipment to do this.
Since the compressor isn't getting hot to touch, then more than likely the sealed system is blocked and the compressor is using more amperage to try and push the refrigerant through the lines. Since it can't, the high amperage is telling the computer that there is something wrong and it needs to be checked by a service tech with sealed system knowledge.
n1vzx
new hampshire
I reclaimed the freon out of the system and it draws about 1.2 amps before the it shuts down and the green light comes on-there is no restriction.whats does the blinking light mean? Blinks 6 times.
Whiteke12
Minnesota
I have same issue, comp is hot, but fridge gets down to temp and freezer sits at 15 degrees with lots of frosting on evaporator-more than usual if I switch to a different board, so I would believe system is not blocked. Could issue still be compressor.
Post a picture of the evaporator/cooling coils.
jesusgrivas
Houston
I'm having the same issue with a kenmore 795, but compressor runs at .84 amps/ > 80 volts. not hot,
evaporator not cooling, all fans running, it stops after 20-30 minutes and led on board flashes 6 times
JoeKenmore
California
Hello,
I am having the same issue with a Kenmore 795.74043.410. Has anyone resolved the green led flashing 6 times on the main board. I already replaced the main board and temperature sensor but didn't fix it. Thanks.
--->6 blinks means there's something wrong with the compressor.
Is the compressor running? If so and its not cooling at all, then you have a sealed system problem.
The sealed system consists of the compressor, condenser, evaporator, heat exchanger, filter/drier and refrigerant. Common problems with a sealed system are bad compressors, refrigerant leaks, and system restrictions. Sealed system repair costs will often exceed the machines value.
If your compressor is NOT running, then unplug the refrigerator and remove the compressor start relay device and ohm test it with a multimeter set on the lowest ohms of resistance, I set mine on 200 ohms.
Normal ohms should be between 0 to 12 ohms on your model.
Here's the compressor start device for your model:
EBG60663230 Thermistor Assembly,ptc
