- LRE3194ST
- LG
- 1-5 years
I was having an issue where the oven would not get up to temp, or if it did get up to temp it would not hold it properly. I had originally bought a new temp sensor to install but when I pulled off the back cover to install it I found that this wire on the lower heating element had been burnt off. I measured the resistance on the heating elements and found the top one to be about 20Ω, the bottom to be about 24Ω and the small convection coil to be about 75Ω. This connector was the only one that showed any signs of heat damage. I plan on replacing the wire and connector but I guess I am unsure of root cause. Is it common to have a loose connector that can cause this failure? Or should I expect to see this happen again when I install a new wire? The unit is only about 2 years old.
