FIXED LG Oven Pop Sound now will not heat
jkwaldron
colorado springs
LRE30755ST
LG
My oven (LG model LRE30755ST) made a loud pop sound when pre heating along with a chemical/burn smell. And obviously the oven is now not heating up. The burners still work. Taking off the back cover I found a black burn area from one of the circuit boards (?) and specifically from one of the black electrical connectors on that board. Do I need to replace the circuit board? If I can up load a pic I will. Thanks
jkwaldron
colorado springs
Thank you. I ordered the control board. Those wires just pull off, right? No special tool needed? I wasn't sure what you meant when you said "with the exception of the stat above". And the wire connector spades go off and on pretty easy? thanks again
Correct.
See attached.
Cut off old, bare wire and crimp/squeeze on new connector.
