Z5b5
- FG4331ES
- LG
- More than 10 years
Hello, I have an LG FG4331ES. The issue I'm having is it won't accurately read the temp. It'll come on and start tracking the temp as it rises but then goes way off. It will only go up 10 degrees when the oven has gone up 100 degrees. I tried calibration to no success.
This is the second time this has happened. My temp probe is reading at 1070OHMs which is correct (both at the probe connector then again at the board connector) I previously replaced both this probe(even though it was in the correct ohms range) and the pcb board that it plugs into. This worked for about 6 months now I have the same issue.
If I turn the oven off then back on it will read the accurate temperature, until it starts to rise again. Then I get incorrect reasons.
My igniter is reading at 360 ohms and the manual says 40-400 is in range.
Any ideas or suggestions?
