LG range -- burner staying on
kilbourne3
dc
LRE30451
LG
The right front burner (12") of our LG range (electric, ceramic cooktop) won't turn off. The display says "HS", which is what it's supposed to say when the burner is off and cooling down after use, but the unit stays on. I killed the circuit, turned the circuit back on, and the burner heated back up again. What little I've read suggests it's a faulty burner switch. If that's correct, anyone know if the switch is behind the button on the control panel or down by the burner under the glass? Any other ideas? Thanks for any information.
Your welcome.
