FIXED LG Range LDE3015ST - front left burner not working.
larsinaz
az
LDE3015ST
LG
I can turn the burner on and adjust temp via control panel but alas, no heat. I tested continuity on the burner and it checks out. Any thoughts?
I couldn't locate the service manual or tech. data sheet for this model.
Hopefully another tech. that works on LG Ranges day in and day out can assist you.
larsinaz
az
Thanks for trying Jake. I've lived in Az since the 70's and had to look up McMullen Valley as it's the first time ever hearing it. Now I know. I go rockhounding out that way.
Yes, we are 25 miles east of Quartzsite, Arizona.
larsinaz
az
In case anyone with the same model range and the same/similar issue stumbles across this looking for a possible fix...
Although I tested the original burner for continuity and it checked out fine, I did try a new burner to be certain. It did not work either. What did fix the issue was replacing the 'surface element control board'. Part# for mine was EBR73254503
Excellent, glad to hear the surface element control board fixed it.(y)
