LG Range LDE3037ST right front cooktop element gets hot but cuts out under high demand
scstarr
LDE3037ST
LG
the right front cook top element stopped working replaced it the new one, gets hot but cuts out under high demand. Now the front right one is not heating as hot as it should either? Control board issue?
So when you have it set to high it cuts out then does not come back on?
scstarr
stays on but at lower heat output the left front was working fine till I replaced the right one that did not work at all , now it is not running as hot as it should just like the new one is
That's very strange, replacing one burner should not effect any other burners.
I really don't know the cause of this problem, I've never seen that happen before, hopefully another tech that has seen this problem before can shed some light on it, if not then you'll need to Contact LG to come out and see what's going on.
Here's the right front burner for your model:
