LG Range LRE30453ST Oven will not reach temp
Gard
Wyoming
LRE30453ST
LG
Replaced temp sensor oven still heats to 335 instead of 375 and 350 instead of 400. Element glows nicely, what else could it be?
These LG models are notorious for the relay board going bad and causing this problem. What happens is the heat relay on the board sticks either ON or OFF at times and will throw your temperatures off, or won't heat at all.
Here's the relay control board for your model you can order:
Relay Board 6871W1N012B
Its located in the back of your range, so you'd pull your range out from the wall, then unplug it, then remove the back access panel, then you will see it on the lower right side.
(click to enlarge)
Gard
Wyoming
Thanks Jake, another symptom is it reaches a temp then begins to cool, does this relate to the same part as well?
Yes, it does.:)
Gard
Wyoming
Well Jake that was not it either. Stopped at 335 degrees again. Thoughts this is nuts replaced two parts and neither helped.
That's very odd, I've replace many of these and its always fixed it.
You will need to have LG come out and see what's going on.
Gard
Wyoming
Could it be the other circuit board behind the control panel? I could return this part for credit towards the next piece. Thoughts
Are you referring to this one:
EBR74632605 Pcb Assy
You bet! That's the only part left that can cause this problem. I've never seen that one go out, but as they say "There's a first for everything." LOL
Gard
Wyoming
The day it happened there was a noise like shorting wires a little light smoke, but no burning electrical smell. I will go that route next then if you agree it is possible.
Let ya know soon hopefully.
Ok, sounds good, yes keep us posted.:)
Gard
Wyoming
The have been killing me. First part looked right, matched mine exact but was someone's damage part missing connections and was obviously meant for garbage.
Part I received Friday was brand new, wrapped in plastic but had additional plugs, ports had different numbers etc. Called gal said it shows to be correct, its not. Kept hounding for part number on mine and the numbers I gave don't match anything but the first broken piece I got had the same numbers as mine.
Need some help here. Simple to change just not getting the part.
Gard
Wyoming
Jake i just need someone to send the right part. I paid for a part i can not use.
Where are you getting these parts?
What is the part number tagged on the box it comes in?
Take a photo of the part number tagged on the box it comes in.
Ok, I still need more information.
Part number on the box it came in, take a photo of it please.
Gard
Wyoming
Has same label as the box the damaged one came in. This is off new box. What you wanted?
