LG Range LRE3083BD - Rear Burner Control Turns On Front AND Rear Burners
KurtM
Illinois
LRE3083BD
LG
LG Range LRE3083BD - When the left rear burner control is turned on, both the left rear burner AND the left front double burner turns on. At that point the controls for the left front double burner have no effect and the left rear control regulates both. If the left front burner is turned on without the left rear, it functions normally. If the left front burner is turned on first, left rear burner control will regulate both burners as soon as it's turned on.
Any suggestions?
Thank you in advance for anyone offering suggestions.
Turn the power off to your range and try reseating the keytail(ribbon cable) into the control board.
If that doesn't solve it then you will need this part:
EBR77562705 Pcb Assembly, Main
KurtM
Illinois
Thank you, Jake, for your suggestion. I did not get a chance to try your solution as yesterday it started working correctly. If the issue returns, I will try your solution.
Ok Kurt, sounds good.
