FIXED LG Range LRG3081ST Oven Temperature Erratic
DandW
Ontario Canada
LRG3081ST
LG
I am having a strange problem with our LRG3081ST oven. If I set the temperature on the oven display to 400 degrees it comes on and the temperature rises fairly steady until it hits 395, then it sits there for some time. I put a new oven thermometer inside to check what was going on. When it reaches 395 on the oven control, it actually goes to 500 degrees before it shuts off. Then the temperature in the oven will drop off to below 200 before it comes back on. Then (sometimes) the glow will be in the bottom for some time before it ignites. If I shut the oven off and restart it to 400 again it shows the temperature in the oven at about 190. Sometimes it will restart and other times it won't, just glows but no ignite.
I replaced the oven temperature sensor figuring that was the problem but, I it is still doing it. Seems real intermittent, my wife used it the other day and it seamed to work okay. Then she went to use it yesterday and it gave the problem again. I just don't want to throw a bunch of money at this replacing part by part until I hit the right one.
Any ideas ?
The problem is the oven igniter itself is likely weak. It should take about 45 seconds and no longer than 60 seconds to light the gas.
What happens is when you turn on either the bake or broil cycle the igniter should draw 3.2-3.6 amps to properly open the oven safety valve for bake or broil.
If you'd like to check it, use an Clamp style Amp Probe around one of the igniter wires. You're looking for 3.2 to 3.6 amps.
OR
Here's a diagram Rick made that shows you how to test for 3.2-3.6 amps for the bake cycle. You can use a multimeter to check for 3.2-3.6 amps when its on the bake cycle and see what reading you get.
(click to enlarge)
Here's the oven igniter for your model:
MEE61841401 Ignitor
DandW
Ontario Canada
Thanks Jake
It seems to start up fine each time. It's after it gets to temperature that the problems start. So, after oven gets hot...
Yes, I understand what your saying, but the only way to test it is what I described above, other than that you'd need a LG tech. to come out and see what's going on.
DandW
Ontario Canada
I had a look this morning and the wire has a connector. Can't see how I would leave one wire connected and disconnect the other. Maybe I am missing something ??
Your not reading the diagram I posted properly, I will enlarge it.
evergladesdrew
Riverside CA
Hi All,
So my oven's experiencing similar issues. What would be the next step if the ignitor is weak and there's <3.2 amps of current going to it? Replace the ignitor? or Replace the control board?
DandW
Ontario Canada
It turned out that my issue was the igniter. Although it looked to be working with the glow, the amps were low and described above. Replaced it and all is now working great again.
Thanks @DandW for coming back to let us know the new igniter fixed yours.(y)
9 times out of 10 its just a weak ignitor.
Do you have the same model number LRG3081ST?
Ok, then I'd order it, if you want to verify it first do what I mentioned above per the amps test.:)
Kathryn McCool
Grayling, MI
I have an LG LRG3081ST gas range with temperature regulation issues; I read the above information. I turned on the oven and it took 70 seconds for the gas to ignite. Prior to that, I set the temperature at 350 and at some point it stopped heating and dropped to 170. Yesterday I set it at 425 and it heated up to over 450, and then, no matter where I set it, it wouldn't heat to over 400. Is it the ignitor or the thermostat or both? Thank you in advance.
Kathryn McCool
Grayling, MI
Hi Jake, can you help with my question above regarding the temperature irregularities in my oven? I just turned it back on and it took 75 seconds for the gas to ignite.
Thank you,
Kathryn
Sounds good Kathryn, let us know how it goes.
Kathryn McCool
Grayling, MI
I replaced the igniter - easy to do. Set the oven to 375, and the igniter lit up within 20 seconds! I think, GREAT! It heats up to 435 and doesn't stop heating (it's gas). Half the problem solved; Now what?
