Telkwa
- LDN22735ST
- LG
- More than 10 years
Trying to figure out what's broken.
The LG is not keeping things cold. It's out on the porch now, not in service.
I've been googling for ideas to test the compressor.
Checked for continuity between the 3 compressor pins. Got something with every combination of pin. So that's good, right?
Then I checked each pin to the outer shell of the compressor. Basically, checking pin to ground. I got continuity with every pin. That's bad, right?
On our LG, the start relay only attaches to two of the three compressor pins. Attached to the third pin (the lowest of the three) is a small electronic gizmo of some kind. It's got a white nylon body, and a black wire coming off of it. I don't know what this thing does.
My wife and I ran this test a few times to make sure. We plugged the fridge in. The circuit board makes a soft "tick" and the fan that blows across the coils spins up. About 30 seconds later that little white plate attached to the lowest pin on the compressor makes a distinct "tick" noise. Sometimes we thought we saw a little spark or arc at the white plate.
I've dug into some of these appliance websites but can't find any mention of the white plate attached to the third pin.
I'll try to attach a pic.
