FIXED LG Refrigerator LFX31945ST/01 Fans not running in run mode
willow dale
Manitoba
LFX31945ST/01
LG
Hi I'm new to this,I can test and do refrigeration,I changed compressor on this unit, weighed proper 134a in unit,PCB Board twice,Defrost sensor changed ,freezer temp sensor changed, i can't get Freezer fan/fridge fan to run in run mode, in text mode they run nicely, what next step?
,PCB Board twice
Where did you get the boards? How long ago? Are there any error codes? If an error code is displayed the fan won't run. Usually when the fan won't run except in test mode the board is the problem. I don't have a tech sheet for that model but I think the wiring is the same for the fans. Locate CON6 and measure the voltage across the gray wire and blue wire (1 to 2 in this image). If it's less than 12 VDC the board is bad.
Anytime Rick!
In your 1st post you mentioned you already replaced the freezer temperature sensor. Did you ohm test it?
This is the freezer temperature sensor for your model:
ACQ73244001 Temperature Sensor
