drewb0y
- LFXS24623S
- LG
- 1-5 years
We have an LG LFXS24623S fridge that is driving us bonkers. There is a lingering smell that we can not seem to get rid of. What we think happened is that defrosting meat released some juices that got down into the drain system. The smell is not inside the refrigerator compartment at all.
What we have done so far -
Flushed the drain and drain tube with hot water and bleach solution
Sucked out all fluids from the drip tray with a wet/dry vacuum and flushed with hot water and bleach solution
Tried adding vanilla extract in the drip tray
Used an odor "sponge"
What I think will fix it is removing the drip tray and cleaning it thoroughly. I have the factory service manual but it does not say how to do this properly. I can remove the screws holding in the evaporator coils but can only pull it out a bit to give more cleaning space. I have only tried this through the rear access panel. Under the evaporator coils are the copper lines that feed into and out of the coils. These copper lines are stuck in a hard waxy like substance which doesn't dissolve easily with hot water and we can't really access it to clean it properly.
Is this normal or should those copper lines be free floating? If we remove the freezer compartment and open that access panel, will it help to clean further. I'm afraid to pull too hard on the tubing or evap coils and turning a cleaning job into an expensive repair.
How do you completely remove the drip tray or is it even possible?
Thanks in advance for any advice. The first pic is from the service manual. Our unit has the evaporator fan to the right of the coils. Second pic is a diagram also from the service manual of how ours is layed out.
