LG Refrigerator LFXS30766S/02 fridge section hovering around 47 degrees when set to 33deg. Ice found on upper left of fridge evaporator.
eaglei
Midwest
LFXS30766S /02
LG
Hello, I have an LG fridge: LFXS30766S /02 I purchased in 2016. The freezer and ice maker work fine, only the refrigerator section is having an issue. I've had this issue in the past (I believe twice in the last two years), and I would clean the coils by the compressor, run and reset the fridge by running the diagnostics using the button on the main board. And also unplug from the wall. This time however after all of that the fridge will bounce around from 42 to 50 degrees. I usually set the temperature to the recommended 37F and 0F for fridge and freezer. I lowered the temp to 33F just to see, and it has been staying around 47 deg mostly.
I started investigating a few days ago and noticed a block of ice forming between the left crisper drawer and back wall, I took out all of the drawers and shelves, and removed the back panel to look at the evaporator. The upper left side where the tubes come in also had a block of ice on it. I defrosted it with a blow dryer, and hoped this would help, which did not. I ran the diagnostics testing which showed the fans were working, and the heating element turned on and got warm. So I tried replacing the Defrost Sensor yesterday with no luck. Not too sure where to go from here. Basic research showed another possible cause could be the thermistor that is near the compressor. When I replaced the defrost sensor I thought that had the fridges temperature sensor in it as well, but now after more investigating I believe it is on the back panel of the fridge near the middle crisper between the vent and led light. Could that be an issue as well?
I noticed when I melted the ice, once the ice started to melt off the copper pipe, that section immediately started frosting over. Would the block of ice formed over the pipe restrict the refrigerant from the compressor from flowing properly? Also the next day I pulled off the cover again, and noticed ice forming at the bottom of the first row coil fins, just the start of it, across maybe 4 or 5 fins. Looked kind of wet to ice, almost like when ice in ice trays are freezing but not completely frozen.
I know these fridges have a well known compressor issue, but seeing how the freezer is working and the fridge is staying at least in the 40's could it still be a compressor issue? Thank you for your time.
Yes, because your model has a dual evaporator, one in the freezer, one in the refrigerator.
That photo you uploaded indicates a sealed system problem.
Look at the last photo below, where it says NORMAL FROST PATTERN.
eaglei
Midwest
Thanks Jake, I did ask on a few different forums, and a sealed system issue seems to be the going consensus. Someone else mentioned at the factory they had issues with the Flux being splattered around on the evaporator coil during assembly possibly causing very tiny holes over time resulting in a slow leak. I'm considering adding R134a with stop leak using a bullet piercing valve just to try and attempt salvaging it as a secondary fridge. I do plan on purchasing a replacement though. What are your thoughts/ recommendations on this?
eaglei
Midwest
Btw, checked this morning, and now the fridge section is around 37 degrees.. Fridge is set to 33 though. Checked the freezer yesterday and it was at -2.
eaglei
Midwest
Now it's down to the 33 degrees I set it too.. So not sure why it's suddenly starting to work again.
eaglei
Midwest
I think I found the issue. I was looking around near the compressor and noticed some liquid on the line, and a lot of corrosion. I believe it's leaking freon right here.
