repair_newbie
- LMXC23796M
- LG
- 1-5 years
Fridge is barely over a year old. About 3 months ago, it stopped cooling, fridge got to over 60 inside. Freezer was thawed out. All ice in ice maker melted. I called LG since it was under warranty and they setup a service call for a few days later. I called back and cancelled two days later, because temps got back to normal.
Fast forward to this week....it happened again.. we first noticed the ice seemed a little thawed, and then noticed a puddle of water under the ice maker. This was 3 days ago. So i called LG and they setup a service appt for yesterday. Day before yesterday, fridge was 70 degrees inside and freezer was 68 in the morning. But then by the evening, it started cooling again. When I went to bed, it was 20 in the freezer and 50 in the fridge. Of course by the time the repair guy got here yesterday, it was back to normal-ish. 43 in fridge and 10 in the freezer (Still not all the way back to normal temps) He said, since its working now, theres nothing he can really do. He did check for error codes, and there were none. And made sure the fans were working. And he did say the compressor was hotter than it should be, which he measured with a temp gun.
He said he was thinking maybe theres no enough air flow behind the fridge, and was causing the compressor to overheat. I asked him why it would cause the fridge to stop cooling for a couple days, and he said maybe the compressor kept trying to come back on, overheating, and causing the thermal shutoff. I asked him why it would all the sudden recover after a couple days and start working normal again, rather than just continuing to try to come back on, overheat, etc, and he didnt have a great answer.
He instructed me to clean the coils. Which i did, and they really werent that dirty, but did have a little dust on them. He also pointed out how the fridge is setting inside a wooden box essentially (not in open air), and that he tells customers to cut vent holes into the cabinets to the left and right of the fridge, and maybe even the cut a couple holes into the cabinets above the fridge, to allow more airflow and heat to escape.
A couple questions:
A couple questions:
- Does his concern about the heat and airflow have any legitimacy? Should I cut the vent holes he has mentioned?
- Based on my description of the symptoms, does it sound like the compressor overheating like he has said, or does this sound like a different issue?
