LG Refrigerator LSC27926ST Dispenser Water line cracked
MICRONS
SOUTH CAROLINA
LSC27926ST
LG
Working on a LG refrigerator, The water line that goes to the water dispenser is cracked and leaks, How can I replace this water line? I do not have any manual for this unit, Is this a easy repair?
Any help will be greatly appreciated.
Michael
This should be it:
I had never installed this water line tubing before, so I can't tell you how, but when you click the link to that part, you will see the instructions to do it, from others who have done it.
MICRONS
SOUTH CAROLINA
Jake. Thanks for your response, But researching, The water line is cracked at the bottom of the freezer door, And all suggestions is that the door has to be replaced which is NLA. Is this accurate? It is broken on the elbow, and cannot attach any tubing. See attached..
Yes, if its the water line tubing that goes up into the freezer door, you are correct, the whole door has to be replaced.
Glad to help Michael.
