LG Refrigerator LSXS22423S icemaker dispensing water
RobertPB
Lake Charles, La
LSXS22423S/00
LG
LG LSXS22423S side-by-side had low water pressure/volume, along with small ice cubes. Replaced water inlet valve at rear. Now getting correct water volume and pressure but icemaker not working. First just made knocking noise when trying to go through ice-making cycle. Found one of teeth of ice maker stuck behind piece of plastic. Freed and mechanism began rotating to correct position and noise stopped.
Now, at end of ice-making cycle, no ice made. Water released out through door dispenser onto floor. Water dispenser still working. Everything in freezer still frozen including water in old fashion ice trays. Any suggestions as to cause?
Did the water not go into the ice maker tray when the ice maker was filling with water? Is there ice in the ice maker tray slots?
RobertPB
Lake Charles, La
No ice in any part of ice maker. Almost seems like the water isn’t going into ice maker until it gets to the point when it’s suppose to dispense the ice. Then the water goes straight through it.
